[GRASS-dev] Re: [GRASS GIS] #1137: wxGUI doesn't work in Windows
GRASS GIS trac at osgeo.org
Thu Aug 26 16:03:13 EDT 2010
 Reporter:  glynn    |       Owner:  grass-dev@…
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  6.4.0
Component:  wxGUI    |     Version:  unspecified
 Keywords:           |    Platform:  MSWindows XP
      Cpu:  All      |
Comment(by martinl):
 Replying to [comment:6 hellik]:
 > Replying to [comment:5 martinl]:
 > > Replying to [comment:4 glynn]:
 > > > Replying to [comment:3 martinl]:
 > > > > is r43266 sufficient fix?
 > > > I think so.
 > > backported to devbr6 (r43274) and relbr64 (r43275). WinGrass packages
 will be available at http://josef.fsv.cvut.cz/wingrass/grass64/ within one
 hour, please test.
 > I've tried r43283
 It wasn't indented to fix grass.py script. The original report
 This is problematic if globalvar.ETCDIR contains a recognised backslash
 sequence, which is quite likely on Windows. In particular, \g is used to
 insert the contents of a named or numbered group, and ETCDIR will almost
 certainly contain this sequence as part of "\grass-". This results in the
 error:
Ticket URL: <http://trac.osgeo.org/grass/ticket/1137#comment:7>
