[GRASS-dev] [GRASS GIS] #1142: r.in.poly fails in LL
GRASS GIS trac at osgeo.org
Thu Aug 26 20:52:12 EDT 2010
 Reporter:  hamish       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  6.4.0
Component:  Raster       |     Version:  svn-releasebranch64
 Keywords:  r.in.poly    |    Platform:  Unspecified
      Cpu:  Unspecified  |
 As reported on the -dev list, r.in.poly is not working in lat/long
 locations.
 http://lists.osgeo.org/pipermail/grass-dev/2010-August/051769.html
 http://lists.osgeo.org/pipermail/grass-dev/2010-August/051773.html
 apparently it works in 6.3.0 but fails in 6.4.0svn. (I can reproduce it
 too)
 Remember to run g.region first(?),
 g.region s=34 n=37 w=-79 e=-77 res=0:01 -p
 r.in.poly in=- out=test << EOF
 A
  -78.254 35.82
  -78.005 36.201
  -77.707 36.135
  -77.84 35.853
  -78.196 35.721
  -78.254 35.82
 = 1 coord
 EOF
 r.univar test
 I have tested r.digit in 6.4.0svn, which is just a front-end to r.in.poly,
 and it works. The .tmp file it creates looks like this:
 AREA
  78:10:08.695652W 36:36:33.569132N
  78:39:25.217391W 35:39:15.62701N
  78:08:24.347826W 34:56:25.85209N
  77:26:57.391304W 35:43:53.440514N
  77:37:23.478261W 36:31:38.392283N
  78:00:17.391304W 35:34:37.813505N
  78:14:12.173913W 35:50:15.434084N
  77:58:50.434783W 36:32:13.118971N
  78:08:59.130435W 36:38:00.385852N
 = 3 label
 I suspect if you try r.in.poly with D:M:Sh coord notation in it will work.
 I have just build 6.4.0rc2, and there it still works there. Will try newer
 RCs later to try and narrow down the time of this change.
 Also, r.in.poly should really be creating geodesic lines between vertices
 when in a lat/long location. need to check that too.
 thanks,
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1142>
