[GRASS-dev] Re: [GRASS GIS] #1142: r.in.poly fails in LL
GRASS GIS trac at osgeo.org
Fri Aug 27 05:56:07 EDT 2010
 Reporter:  hamish       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.0
Component:  Raster       |     Version:  svn-releasebranch64
 Keywords:  r.in.poly    |    Platform:  Unspecified
      Cpu:  Unspecified  |
Changes (by marisn):
  * priority:  major => normal
Comment:
 Everything seems to work just fine on AMD64 with current 6.4. svn, if
 region is set correctly. IMHO this is the real bug, as r.in.* should not
 be affected by current region.
 As goes for Helena's second example - minutes exceed 60 (35:82:00.0N) and
 thus whole line gets ignored.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1142#comment:2>
