[GRASS-dev] GRASS 7: v.in.ogr segfault
Markus Metz markus.metz.giswork at googlemail.com
Fri Aug 27 10:09:22 EDT 2010
Markus Neteler wrote:
> Hi,
> I am importing the national boundaries of Italy as SHAPE file (UTM32) which has
> been generated from two parts in QGIS (SHP merge tool).
> GRASS 7.0.svn (patUTM32):/tmp/ddd > v.in.ogr
> italy_limits_minambiente_full_UTM32_WGS84.shp
> out=italy_limits_minambiente_full_UTM32_WGS84
> Clean boundaries at nodes:
> Segmentation fault
> in GDB:
>  41%
> Program received signal SIGSEGV, Segmentation fault.
> 0x00007ffff79b0d52 in Vect_get_node_coor (map=0x7fffffff8e50,
> num=1754, x=0x7fffffff8cc0, y=0x7fffffff8cb8, z=0x7fffffff8cb0)
>    at level_two.c:228
> 228         *x = Node->x;
> I can make the map available if desired.
Yes please. I have an idea about what has happened but need the
problem map to make sure.
Markus M
