[GRASS-dev] [GRASS GIS] #902: nviz (tcl) fails on wingrass
GRASS GIS trac at osgeo.org
Tue Feb 2 02:56:29 EST 2010
 Reporter:  hamish    |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  6.4.0
Component:  NVIZ      |     Version:  svn-releasebranch64
 Keywords:  wingrass  |    Platform:  MSWindows XP
      Cpu:  x86-32    |
 with the latest WinGrass nightly build installer (r40766), installed in
 C:\Program Files\, nviz (tcl) fails to start.
 even from the MSys command prompt there error is:
 GRASS 6.4> nviz --help
 Sorry <Files/GRASS-64-SNV/etc/nviz2.2/script/nviz2.2_script> is not a
 valid option
 Description
  nviz - Visualization and animation tool for GRASS data.
 Keywords:
 Usage:
 If I reset $GISBASE beforehand to get rid of the space, it works:
 GRASS 6.4> export GISBASE=/C/PROGRA~1/GRASS-64-SVN
 I assume we could hardcode that conversion as part of the GRASS-
 Installer.nsi (as follows), but it would be good to fix it properly.
 ;Get the short form of the install path (to allow for paths with spaces)
 VAR /GLOBAL INST_DIR_SHORT
 GetFullPathName /SHORT $INST_DIR_SHORT $INSTALL_DIR
 also just to note that the nightly build process still is shipping
 msys/grass70.* files and does not use a copy of msys.bat with all paths
 "quoted" which causes (non-fatal) errors in the startup.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/902>
