[GRASS-dev] Re: [GRASS GIS] #910: wxgui: fails with make -j
GRASS GIS trac at osgeo.org
Fri Feb 5 15:03:55 EST 2010
  Reporter:  hamish     |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect     |      Status:  new
  Priority:  normal     |   Milestone:  7.0.0
 Component:  Compiling  |     Version:  svn-trunk
Resolution:             |    Keywords:  wxgui, Makefile
  Platform:  Linux      |         Cpu:  x86-64
Comment (by glynn):
 Replying to [ticket:910 hamish]:
 > gui/wxpython/ fails with:
 GISBASE="/usr/local/src/grass/svn/trunk/dist.x86_64-unknown-linux-gnu" \
         python gui_modules/menudata.py > menustrings.py
 IOError: [Errno 2] No such file or directory:
 '/usr/local/src/grass/svn/trunk/dist.x86_64-unknown-linux-
 gnu/etc/wxpython/xml/menudata.xml
 menudata.py uses the installed menudata.xml, not the source file, so that
 should be the pre-requisite for menustrings.py.
 Fixed in r40832.
Ticket URL: <https://trac.osgeo.org/grass/ticket/910#comment:1>
