[GRASS-dev] lidar tools update in grass7
Markus Neteler neteler at osgeo.org
Mon Feb 8 14:38:29 EST 2010
On Mon, Feb 8, 2010 at 5:18 AM, Hamish <hamish_b at yahoo.com> wrote:
> Markus Metz wrote:
>> I forgot to mention, there is a problem with sqlite, it is much slower
>> than dbf, no idea if this is a problem of my system or of the grass
>> sqlite driver or of the way auxiliary tables are accessed by the lidar
>> tools.
> that sounds vaguely familiar, but as a general thing not necessarily
> to do with v.lidar. probably something about it in the archives?
I found some older conversation incl. patches and speed tests:
... perhaps useful?
On Mon, Feb 8, 2010 at 9:17 AM, Markus Metz
<markus.metz.giswork at googlemail.com> wrote:
> I discovered two little tricks: first, create the table, close database and
> driver, open database and driver again, work with table, second, creating an
> index on the table if possible helps too. Tested with sqlite and dbf.
I wonder if sqlite is creating some index when creating/closing/opening again?
