[GRASS-dev] Re: [GRASS GIS] #902: nviz (tcl) fails on wingrass
GRASS GIS trac at osgeo.org
Tue Feb 9 05:50:51 EST 2010
  Reporter:  hamish    |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:  6.4.0
 Component:  NVIZ      |     Version:  svn-trunk
Resolution:            |    Keywords:
  Platform:  All       |         Cpu:  All
Comment (by hamish):
 Latest from trunk tests out ok for me too on Linux.
 > This doesn't allow the nviz binary to be used to run arbitrary
 > scripts, but I'm not so sure that works anyhow.
 do you mean nvwish running arbitrary Tcl scripts (no loss) or the ability
 to use the script= option (which is used by d.nviz to set up the 'flight
 path' for animations).
Ticket URL: <https://trac.osgeo.org/grass/ticket/902#comment:18>
