[GRASS-dev] Re: [GRASS GIS] #902: nviz (tcl) fails on wingrass
GRASS GIS trac at osgeo.org
Tue Feb 9 08:21:24 EST 2010
  Reporter:  hamish    |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:  6.4.0
 Component:  NVIZ      |     Version:  svn-trunk
Resolution:            |    Keywords:
  Platform:  All       |         Cpu:  All
Comment (by hamish):
 With the latest nightly WinGrass 6.4.0svn build (r40876), I get this error
 message if 'nviz --ui' is called from the msys command line,
 elev=elevation.dem at PERM, and the '-v' verbose flag is ticked (one -, not
 two).
 the command line in the module output tab is
 nviz -v elevation=elevation.dem at PERMANENT
 the popup window error is:
 __Application initialization failed__
 unknown or ambiguous visual name "elevation=elevation at PERMANENT": class
 must be best, directcolor, grayscale, greyscale, pseudocolor, staticcolor,
 staicgray, staticgrey, truecolor, or default
   [Ok]
 then when you press [Ok]:
 __Error in startup script__
 can't read "src_boot": no such variable
   while executing
 "source $src_boot/etc/nviz2.2/scripts/config.tcl"
   (file "c:/Program Files/GRASS-64-SVN\etc\nviz2.2\scripts\nviz2.2_script"
 line 42)
    [Ok]
 same if you use -v from the msys prompt.
 If you make "-v" the last arg on the command line you get this error:
 "-v" option requires an additional arguement
   [Ok]
 This is the same error message you get if you do:
 wish -v
 I'd be inclined to make that -v in nviz a no-op, but I don't think it
 would help in this case.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/902#comment:19>
