[GRASS-dev] [GRASS GIS] #917: v.digit map creation weirdness on wingrass
GRASS GIS trac at osgeo.org
Tue Feb 9 10:18:04 EST 2010
 Reporter:  hamish    |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect    |      Status:  new
 Priority:  normal    |   Milestone:  6.4.0
Component:  Vector    |     Version:  svn-releasebranch64
 Keywords:  wingrass  |    Platform:  MSWindows XP
      Cpu:  x86-32    |
 in the latest wingrass nightly build (r40876), but also seen before, when
 I make a new map with v.digit when I go to close the map everything sings
 along but then I get this error message at the end of the output:
 Region restored to original extent.
 Building topology for vector map <(null)>...
 Registering Primatives...
 Unable to read vector map
 It's the same if I call v.digit (tcl) from the wxGUI menu, the gis.m menu,
 or "v.digit -n test' directly from the msys prompt with no module GUI.
 It's enough to start up with -n and exit intimately.
 even weirder, when called from the gis.m menu/tcltk module GUI when the
 attribute From window should open I get an empty sqlite DOS box opening on
 top of everything and the tall&thin Form window stays all grey and
 unusable.
 (apparently at some point I switched the mapset to use sqlite as the
 backend)
 but I see the same (null) in the output even if I switch db.connect back
 to use dbf.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/917>
