[GRASS-dev] Re: [GRASS GIS] #922: GRASS installer can not install unser "program files" (Windows7 only)
GRASS GIS trac at osgeo.org
Thu Feb 11 10:18:02 EST 2010
  Reporter:  naokiueda     |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  major         |   Milestone:  6.4.0
 Component:  Installation  |     Version:  svn-releasebranch64
Resolution:                |    Keywords:  wingrass, WIndows7
  Platform:  MSWindows 7   |         Cpu:  Unspecified
Comment (by cristn):
 Replying to [comment:7 hellik]:
 > Replying to [comment:6 hellik]:
 > could this a issue with the UAC in Win7.
 Apparently yes: as for the original reporter, always "Skipped" appears. So
 the locale is not the issue but the problem that I cannot write in
 "c:\Program Files".
 When installing instead in C:\user\somebody\Documents\GRASS-64-SVN\ it
 works ok. So "c:\Program Files" seems to be protected.
 Suggestion: on Windows7, use a different default path.
Ticket URL: <http://trac.osgeo.org/grass/ticket/922#comment:9>
