[GRASS-dev] transform additional points from XY?
Hamish hamish_b at yahoo.com
Sat Feb 13 02:20:19 EST 2010
Hamish wrote:
> If a georeferencing points file and target are set up it is
> possible to use g.transform to say how good the fit is.
> I'd like to go one further: I'd like to pass g.transform a
> handful of x,y
> pixels from the the same neighborhood as the GCPs and get
> an approximate projected easting and northing back.
> If possible at all, I guess we have to write something new
> for g.transform; any good ideas on how to do this?
> It's a similar problem to the i.vpoints module which will
> back-project a
> vector map from the target location over what you are
> digitizing without knowing the source projection terms by name.
I would settle for knowing how to get the module output the transform
matrix used, so I could do the calculation by hand.
thanks,
Hamish
