[GRASS-dev] Re: [GRASS GIS] #827: standalone-installer: execution failed on g.proj.exe -p
GRASS GIS trac at osgeo.org
Sat Feb 13 05:40:04 EST 2010
  Reporter:  timmie        |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  normal        |   Milestone:  6.4.0
 Component:  Installation  |     Version:  svn-releasebranch64
Resolution:                |    Keywords:  wingrass
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by hellik):
 Replying to [comment:21 glynn]:
 > We're already faced with having to create manifests to keep UAC happy,
 so it would be useful if someone could read up on this stuff and figure
 out how to use manifests to control searching for DLLs.
 maybe this information is helpfull:
 http://msdn.microsoft.com/de-de/library/aa375365%28en-us,VS.85%29.aspx
     * Assembly manifests describe side-by-side assemblies. They are used
 to manage the names, versions, resources, and dependent assemblies of
 side-by-side assemblies. The manifests of shared assemblies are stored in
 the WinSxS folder of the system. Private assembly manifests are stored
 either as a resource in the DLL or in the application folder
     * Application manifests describe isolated applications. They are used
 to manage the names and versions of shared side-by-side assemblies that
 the application should bind to at run time. Application manifests are
 copied into the same folder as the application executable file or included
 as a resource in the application's executable file.
     * Application Configuration Files, are manifests used to override and
 redirect the versions of dependent assemblies used by side-by-side
 assemblies and applications.
     * Publisher Configuration Files, are manifests used to redirect the
 version of a side-by-side assembly to another compatible version. The
 version that the assembly is being redirected to should have the same
 major.minor values as the original version.
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/827#comment:24>
