[GRASS-dev] Re: [GRASS GIS] #908: No Font Definition File, windows xp
GRASS GIS trac at osgeo.org
Sat Feb 13 10:27:40 EST 2010
  Reporter:  voncasec      |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  critical      |   Milestone:  6.4.0
 Component:  Installation  |     Version:  svn-releasebranch64
Resolution:                |    Keywords:  v.label.sa, g.mkfontcap, wingrass
  Platform:  MSWindows XP  |         Cpu:  Unspecified
Comment (by hellik):
 Replying to [comment:11 glynn]:
 > Replying to [comment:10 hellik]:
 > > what does this mean for running g.mkfontcap outside a Grass-session
 (and  accordingly for the NSIS-installer)? which parameters have to be set
 for working g.mkfontcap outside a Grass-session?
 > GISRC should no longer have to be set. GISBASE must still be set (this
 eliminates the need for the installer to set GRASS_FONT_CAP, as the
 default of $GISBASE/etc/fontcap will work).
 i've tested g.mkfontcap with grass65 running outside a grass-session. it's
 working, fontcap is built.
 I attach a patch for the NSIS-installer script to write a little cmd-file
 to set all dependecies and then run g.mkfontcap outside a grass session.
 the cmd is working by right click with "run as admin" on
 C:\Program Files\GRASS-65-SVN\etc\install_run_gmkfontcap.cmd
 but if it's started by the installer itself, there seems that
 install_run_gmkfontcap.cmd isn't allowed to write fontcap in C:\Program
Ticket URL: <http://trac.osgeo.org/grass/ticket/908#comment:12>
