[GRASS-dev] Re: [GRASS GIS] #929: g.transform: dump coeffs and transform sparse points
GRASS GIS trac at osgeo.org
Sun Feb 14 03:26:20 EST 2010
  Reporter:  hamish       |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  closed
  Priority:  normal       |   Milestone:  7.0.0
 Component:  Imagery      |     Version:  svn-trunk
Resolution:  fixed        |    Keywords:  g.transform
  Platform:  All          |         Cpu:  All
Comment (by hamish):
 I have been pointed to this post by the author:
 http://www.cruisersforum.com/forums/f134/charts-31346-36.html#post398493
 with GPL3 code linked at the end of the post. (remove the .doc; stupid
 webCMS...)
 quote:
  - First for all ref points it converts ref lat/lon in ref E/N using the
 exact projection formulas (Mercator and Transverse-Mercator supported)
  - Second it tries to approximate the ref X/Y to E/N by polynomial approx.
 It tests 23 polynomials to find the best one (minimum error, well
 conditioning). It works with at least 2 ref points.
  - Third it uses this couple of transformations (lat/lon->E/N->X/Y) to
 recalculate 36 new ref points with a disposal that is always well-
 conditioned so it can calculate the final third order polys that goes
 directly form lat/lon to X/Y and viceversa"
 /endquote
 the tests are:
     PolyEleEval - by Marco Certelli - License: GPL - Version 01beta
     This function evaluates the elements of the polynomial that
 approximates a set
     of ref points placed in the plane xy. This is specific for XY<->EN
 transformations
     needed in Chart Georeferencing. One approximating poly is defined as:
     N = a[0] + a[1]X + a[2]Y + a[3]X^2 + a[4]XY + a[5]Y^2 + a[6]X^3 +
 a[7]X^2Y + a[8]XY^2 + a[9]Y^3
     E = b[0] + b[1]X + b[2]Y + b[3]X^2 + b[4]XY + b[5]Y^2 + b[6]X^3 +
 b[7]X^2Y + b[8]XY^2 + b[9]Y^3
     This function takes the int nref, representing number of available ref
 points,
     2 vectors of double x[] and y[], representing the ref points position
 (either
     x, y  or lat, lon), and returns a vector of int e[10] which i-th value
 [1 or 0]
     states if the relative polynomial coefficients a[i] is well or ill-
 conditioned.
     The x[] and y[] input values shall be between 0.0 and 1.0 (the caller
 shall
     scale data). The function itself returns an int 1 if an error
 occurred.
 #define N_POLY_TEST 23
     int i,j,n,t,ne,optt;
     double *A[2*MAX_REF_POINTS+2], B1[2*MAX_REF_POINTS+2],
 B2[MAX_REF_POINTS], C1[20], C2[10];
     double eqmN,eqmE,sN,sE,rcond,sC,prjerror,ill,opt,minopt;
 //                      n X Y X X Y X X X Y a
 //                            X Y Y X X Y Y =
 //                                  X Y Y Y b
     int test[N_POLY_TEST][11] =
                        {3,1,1,0,0,0,0,0,0,0,1, //  0 - P=C + X + Y
 & (Cxx=Cyy, Cxy=-Cyx)
                         3,1,1,0,0,0,0,0,0,0,0, //  1 - P=C + X + Y
                         4,1,1,1,0,0,0,0,0,0,1, //  2 - P=C + X + Y + X^2
                         4,1,1,0,1,0,0,0,0,0,1, //  3 - P=C + X + Y + XY
                         4,1,1,0,0,1,0,0,0,0,1, //  4 - P=C + X + Y + Y^2
                         4,1,1,1,0,0,0,0,0,0,0, //  5 - P=C + X + Y + X^2
                         4,1,1,0,1,0,0,0,0,0,0, //  6 - P=C + X + Y + XY
                         4,1,1,0,0,1,0,0,0,0,0, //  7 - P=C + X + Y + Y^2
                         5,1,1,1,1,0,0,0,0,0,0, //  8 - P=C + X + Y + X^2 +
 XY
                         5,1,1,0,1,1,0,0,0,0,0, //  9 - P=C + X + Y + XY  +
 Y^2
                         5,1,1,1,0,1,0,0,0,0,0, // 10 - P=C + X + Y + X^2 +
 Y^2
                         6,1,1,1,1,1,0,0,0,0,0, // 11 - P=C + X + Y + X^2 +
 XY + Y^2
                         6,1,1,1,1,0,0,1,0,0,0, // 12 - P=C + X + Y + X^2 +
 XY + X^2Y
                         6,1,1,0,1,1,0,0,1,0,0, // 13 - P=C + X + Y + XY  +
 Y^2+ Y^2X
                         7,1,1,1,1,1,1,0,0,0,0, // 14 - P=C + X + Y + X^2 +
 XY + Y^2 + X^3
                         7,1,1,1,1,1,0,1,0,0,0, // 15 - P=C + X + Y + X^2 +
 XY + Y^2 + X^2Y
                         7,1,1,1,1,1,0,0,1,0,0, // 16 - P=C + X + Y + X^2 +
 XY + Y^2 + XY^2
                         7,1,1,1,1,1,0,0,0,1,0, // 17 - P=C + X + Y + X^2 +
 XY + Y^2 + Y^3
                         8,1,1,1,1,1,0,1,1,0,0, // 18 - P=C + X + Y + X^2 +
 XY + Y^2 + X^2Y+ XY^2
                         8,1,1,1,1,1,1,0,0,1,0, // 19 - P=C + X + Y + X^2 +
 XY + Y^2 + X^3 + Y^3
                         9,1,1,1,1,1,1,1,1,0,0, // 20 - P=C + X + Y + X^2 +
 XY + Y^2 + X^3 + X^2Y+ XY^2
                         9,1,1,1,1,1,0,1,1,1,0, // 21 - P=C + X + Y + X^2 +
 XY + Y^2 + X^2Y+ XY^2+ Y^3
                        10,1,1,1,1,1,1,1,1,1,0};// 22 - P=C + X + Y + X^2 +
 XY + Y^2 + X^3 + X^2Y+ XY^2 + Y^3
     int element[N_POLY_TEST][10];
 I am wondering if this is useful for us but I am reminded that in stats
 that the simplest model fit that explains the data is usually the best one
 to use. You can use high nth-order polynomials to exactly fit the data,
 but what you are really doing is fitting the noise.
 So for example I have a good & undistorted scan of a printed map which I
 wish to georectify. I can get a smaller RMS by using order=3, but that's
 just fitting my measurement error better. It's more appropriate to use
 order=2 which will average out my measurement error instead of modelling
 the noise -- which is what I ''really'' want.
 comments?
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/929#comment:4>
