[GRASS-dev] Some string not translated in wxGUI
Markus Neteler neteler at osgeo.org
Thu Feb 18 04:44:38 EST 2010
On Thu, Feb 18, 2010 at 9:49 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> >> Looking around I found other .py files lacking the gettext stuff.
>> > IOW, any module which uses:
>> >        if __name__ == '__main__':
>> > (other than for debug/test/demonstration purposes) should call
>> > gettext.install within that section of code (calling it from the top
>> > level is suboptimal, but probably harmless).
>> So, I would add it  after __main__ in:
>> svn status gui/wxpython/
>> M       gui/wxpython/gui_modules/location_wizard.py
>> M       gui/wxpython/gui_modules/mcalc_builder.py
>> M       gui/wxpython/gui_modules/render.py
> I don't know enough about the GUI and GUI-based startup to know which
> files are executed. The GUI itself is wxgui.py, while G_parser()
> executes menuform.py. Other than that, I don't know.
>> ? This would also activate preferences.py?
> gettext.install makes "_" a built-in function, so it's then available
> for all modules.
I have submitted the fixes, now missing strings are translated.
Markus
