[GRASS-dev] Re: [GRASS GIS] #96: v.surf.bspline column option broken
GRASS GIS trac at osgeo.org
Fri Feb 19 01:24:24 EST 2010
  Reporter:  cmbarton  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  reopened
  Priority:  major     |   Milestone:  7.0.0
 Component:  Raster    |     Version:  svn-releasebranch64
Resolution:            |    Keywords:  v.surf.bspline
  Platform:  All       |         Cpu:  All
Comment (by cmbarton):
 The problem is that the module has been in the distribution but has been
 completely broken for a long time. Only recently was it partly fixed so
 that it worked with 3D points. But using an attribute value for the
 interpolation remained broken. At that time, one picked layer=0 to use 3D
 points. AFAIC, this is a problematic design for reasons I outlined
 previously. BUT it did work in the GUI and command line.
 Very recently there has been a commendable attempt to fix the attribute
 value bug. But along with this, for some reason, the way to use 3D points
 was changed from layer=0 (working in GUI) to layer=-1 (not working in
 GUI). And I was not able to get an interpolated map from the attribute
 either. I hope that this all is fixed and will recompile and test as soon
 as possible. But I'm in the middle of an NSF workshop right now and can't
 do it for a couple of days.
 Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/96#comment:28>
