[GRASS-dev] [GRASS GIS] #958: v.krige does not run in GRASS 7
GRASS GIS trac at osgeo.org
Sat Feb 20 16:54:50 EST 2010
 Reporter:  cmbarton  |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect    |      Status:  new
 Priority:  normal    |   Milestone:  7.0.0
Component:  Vector    |     Version:  svn-trunk
 Keywords:  krige     |    Platform:  All
      Cpu:  All       |
 v.krige is installed with GRASS 7 but does not run.
 When you attempt to start it from the menu, it raises an error:
 "ERROR: Required parameter <column> not set:
     (Name of attribute column with numerical value to be
 interpolated)."
 When you try to run it from the command line, it raises an error:
 "Loading packages, please wait...
 Rpy2 not found. Please install it and re-run."
 Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/958>
