[GRASS-dev] Re: [GRASS GIS] #682: Allow compilation in directory with spaces
GRASS GIS trac at osgeo.org
Sat Feb 20 18:19:42 EST 2010
  Reporter:  marisn     |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect     |      Status:  closed
  Priority:  minor      |   Milestone:  6.5.0
 Component:  Compiling  |     Version:  svn-develbranch6
Resolution:  wontfix    |    Keywords:
  Platform:  Linux      |         Cpu:  Unspecified
Changes (by hamish):
  * status:  new => closed
  * resolution:  => wontfix
 Replying to [comment:1 glynn]:
 > Beyond that, the portions of the configure script which you
 > changed are inserted verbatim by autoconf, so the only way to
 > fix this is to fix autoconf; there isn't anything that can be
 > done within GRASS.
 I have now (well some weeks ago) quoted everything in configure.in and
 install-sh that could be quoted, but as Glynn explains there are parts of
 configure which are automatically added by autoconf, and unfortunately
 those bits are not all quoted.
 closing as "wontfix", even though it is more accurately "cantfix".
 (without moving away from autoconf2.13, and to justify that I'd say we
 need a more compelling reason than this problem)
Ticket URL: <https://trac.osgeo.org/grass/ticket/682#comment:2>
