[GRASS-dev] Suggestion: wxGUI as default in G6.4
Markus Neteler neteler at osgeo.org
Fri Feb 26 10:04:38 EST 2010
On Fri, Feb 12, 2010 at 7:22 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Markus Neteler wrote:
>> ... as the subject indicate: any objections to change to wxGUI as default?
I am still MUCH in favour of this change.
>> Make this change from 6.4.0 to 6.4.1 isn't much policy compliant.
>> And I would like to avoid to publish a 6.5 rather than focusing on 7...
> My main concern is that there should be some way to prevent the GUI
> from loading the vdigit and nviz modules.
I agree. Is that hard to accomplish?
My brute-force method is (in GRASS):
rm -rf $GISBASE/etc/wxpython/nviz $GISBASE/etc/wxpython/vdigit
then 'g.gui wxpython' works.
> AFAIK, it handles the case where these modules don't exist. But if
> they do exist and there's something wrong with them (binary
> compatibility issues), the whole GUI is toast.
... which is unacceptable and currently the case on my laptop.
So a functionality test (or whatever) before loading  the vdigit and
nviz modules would be needed. Since the tcl versions of both are
accessible, I don't see it as showstopper to have the wxGUI as
default GUI *if the test was added* and wxnviz and wxvdigit fail.
Markus
