[GRASS-dev] Issues of 6.5 build on WinXP
Jan Tošovský j.tosovsky at tiscali.cz
Sat Jan 2 12:28:41 EST 2010
> 2009/12/28 Jan Tošovský <j.tosovsky at tiscali.cz>:
> > 1) I cannot add a new vector map layer. Only a dummy one is
> added without
> > the standard option dialog. All corresponding messages from
> the Command
> > output tab can be found at the bottom of this e-mail.
> Raster maps are Ok.
> I commented out problematic code in r40191. Now should work.
> Martin
Wow, it works as expected (I can add a vector map via GUI)!
Even the encoding issue is eliminated now, although several strings from the
last build are back in English (e.g. tab labels 'Required' or 'Manual' in
the insert Raster layer dialog).
Many thanks!
Jan
