[GRASS-dev] Problem updating svn add onns
Hamish hamish_b at yahoo.com
Tue Jan 5 09:31:20 EST 2010
Jarosław Jasiewicz wrote:
> When I try update r.stream.basins directory for most of
> files I receive message:
> it is
> svn: Item '/grass-addons/raster/r.stream.basins/global.h'
> is out of date
> svn: Zatwierdzenie nie powiodło się (szczegóły
> poniżej): // this means: commit failed (details below)
> svn: File or directory 'global.h' out of date. try
> updating
> svn: resource out of date; try updating
> what could be the reason for?
someone else made modifications to those files since you last committed.
  https://trac.osgeo.org/grass/log/grass-addons/raster/r.stream.basins
always run "svn up" before you start up again after a break.
  https://trac.osgeo.org/grass/wiki/HowToSVN#Beforemakingchanges
Hamish
ps- also, please use informative commit comments whenever you check
something in, they help a lot with review & maintenance.
