[GRASS-dev] Re: [GRASS GIS] #7: Location wizard: should predefine DB connection for new location
GRASS GIS trac at osgeo.org
Sat Jan 9 22:04:58 EST 2010
  Reporter:  neteler      |       Owner:  hamish
      Type:  defect       |      Status:  closed
  Priority:  major        |   Milestone:  6.4.0
 Component:  default      |     Version:  svn-trunk
Resolution:  fixed        |    Keywords:
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by hamish):
 Replying to [comment:16 cmbarton]:
 > Great. I'll look into porting this to 6.5 and 7 soon. It can't be
 > backported because these are out of sync with 6.4, so I'll have to
 > insert them. I just noticed that the my location wizard doesn't
 > launch at all in 7. So I'll need to check on that too.
 I think this was post was intended for #842, not this report which had to
 do with the VAR file.
 but yes, in my tests so far utm+6.4 plain textbox are now working fine. In
 hindsight the spinbox might have just been a mostly a gimic after all.
 typing in two numbers is not much of a burden.
 thanks- the wx location wizard has really become something to be proud of.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/7#comment:17>
