[GRASS-dev] Re: [GRASS GIS] #587: svn versions should better reflect svn rev
GRASS GIS trac at osgeo.org
Tue Jan 12 20:44:32 EST 2010
  Reporter:  hamish       |       Owner:  martinl
      Type:  enhancement  |      Status:  reopened
  Priority:  major        |   Milestone:  6.5.0
 Component:  default      |     Version:  svn-trunk
Resolution:               |    Keywords:  g.version
  Platform:  All          |         Cpu:  All
Comment (by hamish):
 Replying to [comment:43 glynn]:
 > Replying to [comment:42 hamish]:
 > > the "a:bM" syntax indicates that your tree has local
 > > modifications.
 > The trailing "M" indicates modification; an unmodified tree would
 > have "a:b". IMHO, the "a:" should be stripped; we're only
 > interested in the last revision, not the first.
 so,
  GRASS_VERSION_SVN=
  AC_PATH_PROG(SVN_VERSION, svnversion, no)
  if test "$SVN_VERSION" != "no" ; then
 -   GRASS_VERSION_SVN=`$SVN_VERSION -c`
 +   GRASS_VERSION_SVN=`$SVN_VERSION -c | cut -f2 -d:`
  fi
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/587#comment:44>
