[GRASS-dev] Re: [GRASS GIS] #534: g.gui doesn't work in ms-windows
GRASS GIS trac at osgeo.org
Tue Jan 12 22:50:33 EST 2010
  Reporter:  cnielsen      |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  reopened
  Priority:  major         |   Milestone:  6.4.0
 Component:  wxGUI         |     Version:  svn-releasebranch64
Resolution:                |    Keywords:
  Platform:  MSWindows XP  |         Cpu:  Unspecified
Comment (by hamish):
 testing on wingrass prev binary r40019-
 from the "GRASS 6.4.SVN with MSYS" terminal prompt $GRASS_PYTHON is set
 (presumably by init.sh) and "g.gui wxpython" works.
 from the "GRASS Command Line" menu item DOS-box %GRASS_PYTHON% is not set
 and "g.gui wxpython" fails unless I set it. It is best to fix init.bat of
 course, but perhaps we could also add a check to see if the getenv() in
 g.gui.c is empty, and if it is default to "python"?
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/534#comment:10>
