[GRASS-dev] [GRASS GIS] #877: wxGUI: Location wizard bug when creating LatLong location
GRASS GIS trac at osgeo.org
Sun Jan 17 18:28:46 EST 2010
 Reporter:  neteler          |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect           |      Status:  new
 Priority:  blocker          |   Milestone:  6.4.0
Component:  wxGUI            |     Version:  svn-releasebranch64
 Keywords:  location wizard  |    Platform:  MSWindows Vista
      Cpu:  Unspecified      |
 * Launch winGRASS
  * On the right-hand side select Location Wizard under Define new location
  * Leave the GIS Data Directory field as is but choose a descriptive name
 for the Project Location
  * Continue to the next page
  * Choose Select Coordinate System parameters from a list and continue
  * Type in ll for the Projection Code (or scroll down the page to find
 Lat/Lon)
  * Keep "Datum with associated ellipsoid"
  * Continue to the next page: bug appears "You must enter a value for
 Central Meridian" although values are inserted
 See attached screenshot.
Ticket URL: <http://trac.osgeo.org/grass/ticket/877>
