[GRASS-dev] Re: [GRASS GIS] #878: v.external not working on WinGrass
GRASS GIS trac at osgeo.org
Sun Jan 17 19:14:53 EST 2010
  Reporter:  hellik           |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  critical         |   Milestone:  6.4.0
 Component:  Vector           |     Version:  svn-releasebranch64
Resolution:                   |    Keywords:  v.external, vector, windows
  Platform:  MSWindows Vista  |         Cpu:  x86-32
Comment (by hellik):
 Replying to [ticket:878 hellik]:
 > WinGrass r40456 on WinVista32
 tested within the nc-sample-dataset
 v.out.ogr input=hospitals at PERMANENT type=point dsn=C:\temp\ncdata
 olayer=exporthospital
 Exportiere 160 Punkte/Linien...
 160 Feature geschrieben.
 ogrinfo:
 INFO: Open of `exporthospital.shp'
       using driver `ESRI Shapefile' successful.
 Layer name: exporthospital
 Geometry: Point
 Feature Count: 160
 Extent: (156998.171862, 20235.564401) - (914347.874861, 308097.937401)
 Layer SRS WKT:
 PROJCS["Lambert Conformal Conic",
     GEOGCS["grs80",
         DATUM["North_American_Datum_1983",
 SPHEROID["Geodetic_Reference_System_1980",6378137,298.257222101]],
         PRIMEM["Greenwich",0],
         UNIT["Degree",0.017453292519943295]],
     PROJECTION["Lambert_Conformal_Conic_2SP"],
     PARAMETER["standard_parallel_1",36.16666666666666],
     PARAMETER["standard_parallel_2",34.33333333333334],
     PARAMETER["latitude_of_origin",33.75],
     PARAMETER["central_meridian",-79],
     PARAMETER["false_easting",609601.22],
     PARAMETER["false_northing",0],
     UNIT["Meter",1]]
 v.external dsn=C:\temp\ncdata\exporthospital.shp output=testvexternal
 Data source contains 1 layers:
 exporthospital
 no testvexternal in the vect-list either any error-message of v.external
Ticket URL: <http://trac.osgeo.org/grass/ticket/878#comment:1>
