[GRASS-dev] [GRASS GIS] #881: winGRASS compilation: dumpbin: command not found
GRASS GIS trac at osgeo.org
Mon Jan 18 22:40:07 EST 2010
 Reporter:  ege          |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.0
Component:  Compiling    |     Version:  svn-releasebranch64
 Keywords:  MinGW        |    Platform:  MSWindows XP
      Cpu:  Unspecified  |
 When compiling following
 http://trac.osgeo.org/grass/wiki/CompileOnWindows, the compilation gives
 an error (dumpbin: command not found).
 Errors in:
 No errors detected.
 Finished compilation: Tue Jan 19 12:29:00 TST 2010
 Tue Jan 19 12:29:00 TST 2010: STARTING make install
 echo /osgeo4w/usr/src/grass64_release/bin.i686-pc-mingw32/grass64
 make[1]: Entering directory `/osgeo4w/usr/src/grass64_release'
 /bin/install -c  gem/gem64 /c/OSGeo4W/apps/grass/bin 2>/dev/null
 make[1]: [real-install] Error 1 (ignored)
 make[1]: Leaving directory `/osgeo4w/usr/src/grass64_release'
 Tue Jan 19 12:30:24 TST 2010: STARTING cleanup
 Tue Jan 19 12:30:37 TST 2010: STARTING building vc libraries
 libgrass_I.6.4.0svn.dll => grass_I
 mswindows/osgeo4w/mklibs.sh: dumpbin: command not found
 OCU at OCU-4B9D17344B0 /osgeo4w/usr/src/grass64_release
 Shouldn't dumpbin only for Visual Studio compilation? Here MinGW is used.
Ticket URL: <http://trac.osgeo.org/grass/ticket/881>
