[GRASS-dev] Re: [GRASS GIS] #882: i18n enabled winGRASS: properties dialog not opening
    trac at osgeo.org
    Wed Jan 20 01:18:55 EST 2010
  Reporter:  neteler       |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect        |      Status:  new
  Priority:  blocker       |   Milestone:  6.4.0
 Component:  wxGUI         |     Version:  svn-releasebranch64
Resolution:                |    Keywords:
  Platform:  MSWindows XP  |         Cpu:  x86-32
Comment (by glynn):
 Replying to [comment:3 neteler]:
 > I just discovered that in the terminal some problems are indicated:
 SAXParseException
 <unknown>:1:30: unknown encoding
 > Maybe that gives an idea.
 Look at the first line of the output from `d.rast --interface-
 description`. The encoding= parameter is probably something Windows-
 specific like "CP932". In which case, we may need to use something other
 than locale_charset() (e.g. bind_textdomain_codeset() with NULL for the
 codeset parameter), or even convert the text to UTF-8.
 Except ... GUI.!ParseCommand() assumes that the text is in the locale's
 encoding and is explicitly converting it to UTF-8. But it doesn't change
 the encoding= in the XML header, which will still contain the locale's
 encoding (maybe this pre-dates r17034 being back-ported?).
 The fact that it's xml.sax.parseString() which is failing rather than the
 ".decode(enc)" in the argument suggests that Python understands the
 encoding, so it may suffice to do something like:
 - ... .decode(enc).encode("utf-8") ...
 + ... .decode(enc).split('\n',1)[1].replace('', '<?xml version="1.0"
 encoding="utf-8"?>\n', 1).encode("utf-8") ...
 The situation is complicated by the fact that 6.5/7.0 has abandoned
 xml.sax in favour of xml.etree.!ElementTree.
Ticket URL: <http://trac.osgeo.org/grass/ticket/882#comment:4>
