[GRASS-dev] Re: [GRASS GIS] #885: WinGrass: displaying r.external-linked raster data not working
GRASS GIS trac at osgeo.org
Thu Jan 21 19:07:29 EST 2010
  Reporter:  hellik           |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  critical         |   Milestone:  6.4.0
 Component:  Display          |     Version:  svn-releasebranch64
Resolution:                   |    Keywords:  r.external, WinGrass
  Platform:  MSWindows Vista  |         Cpu:  x86-32
Comment (by neteler):
 Replying to [comment:7 glynn]:
 > Replying to [comment:6 neteler]:
 > > It seems that gdal.c depends on lib/gis/counter.c which isn't in 6.x.
 > > Add that as well?
 > That's overkill; I would just add the following to gdal.c:
 > counter.c was added to 7.0 to support multi-threaded code, which
 wouldn't work in 6.x without a lot of other changes.
 Done so - see attached diff. I am now stuck with these compile error:
 gdal.c: In function ‘G_create_gdal_link’:
 gdal.c:366: warning: implicit declaration of function ‘G__init’
 gdal.c:393: error: ‘struct G__’ has no member named ‘nbytes’
 Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/885#comment:10>
