[GRASS-dev] grass64 install for Mac
Michael Barton michael.barton at asu.edu
Mon Jan 25 09:43:42 EST 2010
I'm in favor of anything that can make installation and use easier for the user, so that they can focus on solving problems with the software, not solving problems IN the software ;-)
Michael
On Jan 25, 2010, at 2:21 AM, grass-dev-request at lists.osgeo.org wrote:
> Date: Sun, 24 Jan 2010 23:55:12 -0500
> From: Helena Mitasova <hmitaso at unity.ncsu.edu>
> Subject: [GRASS-dev] grass64 install for Mac
> To: GRASS developers grass-developers <grass-dev at lists.osgeo.org>
> Cc: William Kyngesburye <kyngchaos at kyngchaos.com>
> Message-ID: <CC57996B-21E7-439C-9F0F-73912CB14448 at unity.ncsu.edu>
> Content-Type: text/plain; charset=us-ascii
> Just a follow up on the Mac installation issues:
> as I mentioned several users reported problems switching from tcltk GUI to wxGUI:
> after running g.gui in all possible ways they kept getting an error message.
> It turns out that the problem was missing FFTW3 library (on Leopard only?)
> - after installing the correct version of FFTW3 everything runs fine.
> Another most common problem was people forgetting to install Active Tcl
> and then complaining that nviz keeps crashing. Or they thought that Active
> Tcl is needed only for Tcltk GUI and when they are running wxpython GUI it is not needed.
> Everything is written on the web site so there isn't really a problem as long as
> the users read carefully the instructions (what nobody does these days).
> As more OS versions and GRASS releases have been added to the web page
> people simply overlook important issues.
> So William and others on Mac, I am wondering whether it would help for future
> to have the instructions for Snow Leopard written in a simpler way something like this
> For Snow Leopard install:
>  - Unix Compatibility Frameworks: SQLite3, FreeType, UnixImageIO, PROJ, GEOS, and GDAL
>  - ActiveTcl 8.5 (not 8.6) from ActiveState
>  - GRASS.app 64
> - sample data set from here: link
> (I am not sure I have it right, but I assume that Python, wxPython and FFTW3
> does not have to be installed separately)
> For older Mac OS X versions I would keep it as is.
> I am not sure that this is the best solution, others may have better ideas,
> thank you,
> Helena
