[GRASS-dev] Re: Scripting in Linux (Kim Besson)
Franz Schiller franzschiller1975 at gmail.com
Tue Jan 26 13:06:43 EST 2010
You are absolutely right Antonio.
Do anyone knows how to have Special Characters in Module (e.g. á, é).
Thanks
PS- At my WinGRASS I had those special characters
2010/1/26 António Rocha <antonio.rocha at deimos.com.pt>
> Kim, probably you have a special character in your module/Option (such as
> á, à , ã or something). Right?
> Because I'm using Ubuntu 9.10 and I have already coded a NDVI function,
> very similar to yours, and it's working just fine. as soon as I put a
> character like those, I get an error like
> *(python:3562): Pango-CRITICAL **: pango_layout_get_cursor_pos: assertion
> `index >= 0 && index <= layout->length' failed*
> and huge wxPython GUI error in command window.
> Antonio
>> Subject:
>> Re: [GRASS-dev] Scripting in Linux
>> From:
>> Kim Besson <kimbesson1981 at gmail.com>
>> Date:
>> Tue, 26 Jan 2010 15:39:59 +0000
>> To:
>> Glynn Clements <glynn at gclements.plus.com>, grass-dev at lists.osgeo.org
>> To:
>> CC:
>> Yeah sure...
>> The following was printed in TERMINAL:
>> (python:2176): Gtk-CRITICAL **: gtk_widget_event: assertion
>> `WIDGET_REALIZED_FOR_EVENT (widget, event)' failed
>> And at the command output it was:
>> <?xml version="1.0" encoding="ANSI_X3.4-1968"?>
>> <!DOCTYPE task SYSTEM "grass-interface.dtd">
>> <task name="i.ndvi">
>> <description>
>> NDVI Calculus
>> </description>
>> <keywords>
>> DW-E, raster, imagery, vegetation
>> </keywords>
>> <parameter name="bandnir" type="string" required="yes" multiple="no">
>> <description>
>> raster input map (Near Infrared)
>> </description>
>> <gisprompt age="old" element="cell" prompt="raster" />
>> </parameter>
>> <parameter name="bandred" type="string" required="yes" multiple="no">
>> <description>
>> raster input map (Red)
>> </description>
>> </parameter>
>> <parameter name="ndvi" type="string" required="yes" multiple="no">
>> <description>
>> raster output NDVI map
>> </description>
>> <gisprompt age="new" element="cell" prompt="raster" />
>> </parameter>
>> <flag name="overwrite">
>> <description>
>> Allow output files to overwrite existing files
>> </description>
>> </flag>
>> <flag name="verbose">
>> <description>
>> Verbose module output
>> </description>
>> </flag>
>> <flag name="quiet">
>> <description>
>> Quiet module output
>> </description>
>> </flag>
>> </task>
>> (Tue Jan 26 15:38:40 2010) Command finished (0 sec)
>> This gives us any light?
>> 2010/1/26 Glynn Clements <glynn at gclements.plus.com <mailto:
>> glynn at gclements.plus.com>>
>>    Kim Besson wrote:
>>    > But, for instance, I have just made a NDVI script (i.ndvi) and I
>>    added the
>>    > file to my script folder  but I got the following error:
>>    > SAXParseException
>>    > <unknown>:5:3: not well-formed (invalid token)
>>    > Could you tell me what's wrong? Am I suppose to do something else?
>>    Can you post the output from "i.ndvi --interface-description" ?
>>    <mailto:glynn at gclements.plus.com>>
>> grass-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
>> __________ Information from ESET NOD32 Antivirus, version of virus
>> signature database 4807 (20100126) __________
>> The message was checked by ESET NOD32 Antivirus.
>> http://www.eset.com
> http://www.eset.com
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20100126/3f74a68a/attachment.html
