[GRASS-dev] Re: [GRASS GIS] #898: WinGrass: r.out.xyz error
GRASS GIS trac at osgeo.org
Sat Jan 30 18:57:51 EST 2010
  Reporter:  hellik           |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect           |      Status:  new
  Priority:  normal           |   Milestone:  6.4.0
 Component:  Raster           |     Version:  svn-releasebranch64
Resolution:                   |    Keywords:  wingrass, raster, path
  Platform:  MSWindows Vista  |         Cpu:  x86-32
Comment (by hellik):
 Replying to [comment:1 glynn]:
 > Replying to [ticket:898 hellik]:
 > > self-compild WinGrass r40741 in osgeo4w-stack
 > r.out.xyz --verbose input=elevation at PERMANENT output=C:\wd\mg\elev.xyz
 > Are you running this via the MSys shell or via cmd.exe?
 also tested in the actual daily WinGrass-build
 (http://josef.fsv.cvut.cz/wingrass/grass64/) via cmd.exe which the
 original r.out.xyz --verbose input=elevation at PERMANENT
 output=C:\wd\mg\elev.xyz, but this also fails in the cmd.exe
 Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/898#comment:4>
