[GRASS-dev] Re: [GRASS GIS] #1101: WinGrass7 + scripts are not
found in the command line
trac at osgeo.org
Fri Jul 2 04:11:58 EDT 2010
#1101: WinGrass7 + scripts are not found in the command line
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Packaging | Version: svn-trunk
Keywords: wingrass, scripts | Platform: MSWindows Vista
Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:5 glynn]:
> Replying to [ticket:1101 hellik]:
> GRASS 7.0.svn> g.manual
> sh.exe": g.manual: command not found
> Check the setting of `%GRASS_SH%`.
> It should be set with something like:
> set GRASS_SH=C:\msys\1.0\bin\sh.exe
> or:
> set GRASS_SH=C:\Program Files\GRASS-70-SVN\msys\1.0\bin\sh.exe
> There shouldn't be any quotes, even if the filename contains spaces.
in grass70.bat, which invokes grass70.py, there is:
rem Set GRASS Installation Directory Variable
set GISBASE=C:\Program Files\GRASS-70-SVN
rem Path to the shell command
set GRASS_SH=%GISBASE%\msys\bin\sh.exe
and in the WinGrass7-command line:
GRASS 7.0.svn> echo $GRASS_SH
C:\Program Files\GRASS-70-SVN\msys\bin\sh.exe
GRASS 7.0.svn>
and sh.exe is in C:\Program Files\GRASS-70-SVN\msys\bin
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1101#comment:6>
