[GRASS-dev] Re: [GRASS GIS] #1032: ErrorCommandExecution g.proj
Maris Nartiss maris.gis at gmail.com
Fri Jul 2 08:57:08 EDT 2010
Markus,
when tracing problems, it's no use for --leak-check=yes
--show-reachable=yes unless You plan to hunt down memory leaks. Also
it's likely that on fine running system vagrind will show nothing, as
bug might be compiler/optimisation/system core libs sensitive.
Just some hints,
Maris.
2010/7/2, GRASS GIS <trac at osgeo.org>:
>  Reporter:  sallar    |       Owner:  grass-dev@…
>      Type:  defect    |      Status:  new
>  Priority:  critical  |   Milestone:  6.4.0
> Component:  default   |     Version:  6.4.0 RCs
>  Keywords:  g.proj    |    Platform:  Linux
>       Cpu:  x86-32    |
> Comment(by neteler):
>  I have added valgrind output (but here g.proj -p works)
> Ticket URL: <http://trac.osgeo.org/grass/ticket/1032#comment:18>
> GRASS GIS <http://grass.osgeo.org>
