[GRASS-dev] build error in wxpython (grass6_devel)
Martin Landa landa.martin at gmail.com
Mon Jul 5 06:49:16 EDT 2010
2010/7/5 Massimo Di Stefano <massimodisasha at gmail.com>:
> wxpython build fine.
> the error is only on nviz,
> i attached a log just to report it (maybe usefull to debug),
> i don't need nviz right now,
> http://www.geofemengineering.it/data/grass_nviz_build_log.txt
> i know there are a lot of work in progress in the nviz code,
> thanks Martin!!!! and All Dev team of course ;-)
please ignore these errors, wxNviz is still broken in develbranch_6.
The C++ component will be replaced by python module wxnviz.py. It
requires to backport ctypes interface from trunk.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
