[GRASS-dev] [GRASS GIS] #1104: rfe: easier to read wx map layer list
GRASS GIS trac at osgeo.org
Fri Jul 9 10:46:03 EDT 2010
 Reporter:  hamish       |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  6.4.1
Component:  wxGUI        |     Version:  svn-develbranch6
 Keywords:               |    Platform:  All
      Cpu:  All          |
 [moved here from #1051]
 for a while I've had the wish to clean up the list of map layers in the
 main wx display tab as I find it rather cluttering and hard to read.
 perhaps: roads @ PERMANENT, or better: roads (PERMANENT)
 both in the map layer-list and in the list of maps selector. actually just
 omit it in the map-selector pull-down list as it is already given by the
 higher level mapset name heading in the mapset tree (blue text).
 ... and the (opacity: 100%) [:] stuff would be better packed on the right
 edge of the row.
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1104>
