[GRASS-dev] Re: i.pr in GRASS6.4
Markus Neteler neteler at osgeo.org
Tue Jun 1 06:21:20 EDT 2010
Hi António,
please consider to submit your changes as "svn diff" to enable others
to make use of the improved i.pr.*.
thanks
Markus
2010/5/20 António Rocha <antonio.rocha at deimos.com.pt>:
> Hi Markus
> Ok I finally managed to understand better what is happening.
> i.pr.Training- Interactive option is failing. Non-interactive requires GRASS
> sites points. So far, I was able to do a testing dataset using interactive.
> What is failing in interactive? Not displaying image
> i.pr.features- I fixed what was not working
> i.pr.model- I believe it's working
> i.pr.classification- Not working, at least for kNN. Doind some debugging...
>> Subject:
>> Re: [GRASS-dev] Re: i.pr in GRASS6.4
>> From:
>> Markus Neteler <markus.neteler at iasma.it>
>> Date:
>> Wed, 19 May 2010 12:23:49 +0200
>> To:
>> grass-dev at lists.osgeo.org
>> To:
>> The MAN manual building script is either not existing on
>> your machine or perl fails:
>> GRASS_PERL=/usr/bin/perl VERSION_NUMBER=6.4.0svn sh
>> /usr/local/grass-6.4.0svn/tools/g.html2man/g.html2man
>> /usr/local/grass-6.4.0svn/docs/html/i.pr.blob.html
>> /usr/local/grass-6.4.0svn/man/man1/i.pr.blob.1 1
>> sh: Can't open /usr/local/grass-6.4.0svn/tools/g.html2man/g.html2man
>> make[3]: *** [/usr/local/grass-6.4.0svn/man/man1/i.pr.blob.1] Error 2
>> That's harmless for the usage.
>> For the rest, there are warnings which should ideally be fixed but
>> warnings are not necessarily errors.
>> Perhaps you would just try the tools?
>> Markus
>> On 05/18/2010 04:41 PM, António Rocha wrote:
>>> Ups forgot the attachment.. Sorry
>>> All executables were created...
>>>> I'm sorry but I need to make a correction regarding this. This was done
>>>> for GRASS6 so Makefiles will be similar to the ones that GRASS6.4 has.
>>>> Ok I have downloaded i.pr into my LINUX (Ubuntu machine)  and I've used
>>>> this command to compile:
>>>> sudo make -C i.pr MODULE_TOPDIR=/usr/local/grass-6.4.0svn &>log.log
>>>> Attached to this email is the installation LOG. I had a few errors,
>>>> regarding Description.html but how is the rest? OK?
>>>> (will it work on GRASS6.4?)
>>>> Thank you
>>>> best regards,
>>>> Antonio Rocha
>>>>> Greetings all
>>>>> I've seen a few emails, at GRASS users mailing list regarding i.pr
>>>>> module. This module, developed for GRASS5 by Stefano Merler , is a
>>>>> multi-tool to perform Classification for a wide set of methods. This is a
>>>>> good asset for GRASS having this tool "fully working" on GRASS 6.4.
>>>>> has anyone tried to "redone" this tool to GRASS6.4.?
>>>>> Thank you so much for your help
>>>>> Best regards,
>>>>> Antonio Rocha
> __________ Information from ESET NOD32 Antivirus, version of virus signature
> database 5130 (20100519) __________
> The message was checked by ESET NOD32 Antivirus.
> http://www.eset.com
> grass-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-dev
