[GRASS-dev] Re: [GRASS GIS] #1081: "Attribute Table Manager" not show data and v.extract doesn't work
GRASS GIS trac at osgeo.org
Tue Jun 1 14:52:20 EDT 2010
  Reporter:  zarch   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  new
  Priority:  normal  |   Milestone:  7.0.0
 Component:  Vector  |     Version:  svn-trunk
Resolution:          |    Keywords:
  Platform:  Linux   |         Cpu:  x86-64
Comment (by martinl):
 Replying to [ticket:1081 zarch]:
 > I have a big vector table (with areas) with 22604 rows and more than 100
 > columns. I'm using grass-trunk 42416 on 64bit Linux system.
 > If I try to visualise the attributes with "Attribute Table Manager"
 grass70 doesn't
 > work with both case using 'dbf' and 'pg' driver.
 What do you mean by "doesn't work"? Any error message, or so? BTW ATM
 needs some optimalization for larger tables, it can be very slow.
 > Moreover I get this error:
 > > v.extract --overwrite input=fustaia output=try01 \
 >  where='accifus=1 AND ripresa>0'
 > ERROR: Database connection not defined for layer <-1>
 Should be fixed in r42420.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1081#comment:1>
