[GRASS-dev] grass7 on mac OSX
Massimo Di Stefano massimodisasha at gmail.com
Wed Jun 2 04:51:47 EDT 2010
Il giorno 02/giu/2010, alle ore 10.41, Glynn Clements ha scritto:
> Massimo Di Stefano wrote:
>> error in wx gui build (i'm using wx-cocoa)
>> log :
>> http://www.geofemengineering.it/data/grass_wxgui_log.txt
> pseudodc.h: In member function ‘virtual void gpdcFloodFillOp::DrawToDC(wxDC*, bool)’:
> pseudodc.h:210: error: invalid conversion from ‘int’ to ‘wxFloodFillStyle’
> pseudodc.h:210: error:   initializing argument 4 of ‘bool wxDC::FloodFill(wxCoord, wxCoord, const wxColour&, wxFloodFillStyle)’
> These are caused by trying to use wxWidgets 2.9. GRASS requires
> wxWidgets 2.8.
yes i suspected the error was related to wx version
mine was just an attempt, beacouse i had to build it
for the new python
>> while start grass in text mode, again  grass.lib is not avaiable as
>> grass.python module
> You'll need to provide the output from "make -C lib/python" if you
> want help with this.
Thanks! i see this log thinking about the wxgui failure ... while was grass lib,
this the log :
http://www.geofemengineering.it/data/grass_lib_python_osx_log.txt
> Glynn Clements <glynn at gclements.plus.com>
