[GRASS-dev] grass7 on mac OSX
massimo di stefano massimodisasha at gmail.com
Thu Jun 3 08:07:53 EDT 2010
humm .. i forghet that :-/
is the local copy of ctypesgen in grass
a modified version from the original source?
If yes exists a "diff" between the 2 versions ?
i tried to contact people on #macdev from irc.freenode.net
but i haven't got answers. I can also try to send a note
to the pythonmac list if this can help.
i hope someone with better knowledge of osx
... and programming in general
can dive into this problem.
Thanks!
Massimo.
2010/6/3 Glynn Clements <glynn at gclements.plus.com>
> Massimo Di Stefano wrote:
> > i opened an issue on :
> > http://code.google.com/p/ctypesgen/issues/detail?id=7
> > i hope what i wrote is correct, tell me if i need to change something.
> Note that GRASS uses a local copy of ctypesgen, so there isn't much
> point reporting issues to the upstream maintainers.
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20100603/8b175cd1/attachment.html
