[GRASS-dev] Re: [GRASS GIS] #1081: "Attribute Table Manager" not show data and v.extract doesn't work
GRASS GIS trac at osgeo.org
Thu Jun 3 09:26:37 EDT 2010
  Reporter:  zarch   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  new
  Priority:  normal  |   Milestone:  7.0.0
 Component:  Vector  |     Version:  svn-trunk
Resolution:          |    Keywords:  v.extract
  Platform:  Linux   |         Cpu:  x86-64
Comment (by zarch):
 Replying to [comment:1 martinl]:
 > Replying to [ticket:1081 zarch]:
 > > I have a big vector table (with areas) with 22604 rows and more than
 100
 > > columns. I'm using grass-trunk 42416 on 64bit Linux system.
 > > If I try to visualise the attributes with "Attribute Table Manager"
 grass70 doesn't
 > > work with both case using 'dbf' and 'pg' driver.
 > What do you mean by "doesn't work"? Any error message, or so? BTW ATM
 needs some optimalization for larger tables, it can be very slow.
 I mean that no any attributes it's shown (I wait for 10 minuts) with
 grass64 to see the same table, I need more or less about 1 minut.
 > > Moreover I get this error:
 > > > v.extract --overwrite input=fustaia output=try01 \
 > >  where='accifus=1 AND ripresa>0'
 > > ERROR: Database connection not defined for layer <-1>
 > Should be fixed in r42420.
 yes, now it's working! thank's
Ticket URL: <http://trac.osgeo.org/grass/ticket/1081#comment:3>
