[GRASS-dev] WinGrass65 + import gui_modules.nviz_tools as nviz_tools: ImportError
Helmut Kudrnovsky hellik at web.de
Sat Jun 5 19:00:12 EDT 2010
>-----Ursprüngliche Nachricht-----
>Von: Martin Landa
>Gesendet: 05.06.2010 23:58:48
>An: Hamish
>Betreff: Re: [GRASS-dev] WinGrass65 + import gui_modules.nviz_tools as  nviz_tools: ImportError
>Hi,
>2010/6/5 Hamish
>> I haven't been paying too much attention, but it would seem to me that if
>> you are moving libraries out of the private $GISBASE tree and into the
>> public osgeo4w lib dir, removing the versioning from the files is the last
>> thing you'd want to do.
>Helmut is trying to do the opposite thing. He is moving grass libs
>from public osgeo4w lib dir into the private $GISBASE tree. It's quite
>reasonable approach for WinGRASS installer.
I will revert r42490, because WinGrass7 (from the WinGrass-installer) seems to need versioned libgrass_*.7.0.svn.dll in C:\Program Files\GRASS-70-SVN\extralib for starting and unversioned libgrass_*.dll C:\Program Files\GRASS-70-SVN\lib for wxnviz. with r42490 WinGrass7 isn't starting, with reverted r42490 WinGrass7 is starting but wxnviz (3D view mode) isn't working.
I will open a ticket because a duplication of files should be avoided.
BTW with versioned and unversioned libgrass, wxnviz (3D view mode) is disabled:
"WARNING: Nviz extension (3D view mode) disabled. Reason: intl not found."
Helmut
___________________________________________________________
NEU: WEB.DE DSL für 19,99 EUR/mtl. und ohne Mindest-Laufzeit!
http://produkte.web.de/go/02/
