[GRASS-dev] r.in.pdf
Jeshua Lacock jeshua at OpenOSX.com
Mon Jun 7 16:54:01 EDT 2010
On Jun 7, 2010, at 11:15 AM, Jarek Jasiewicz wrote:
> Esri solution concerns GeoPDF, created with ESRI and imported back as set of data and ESRI layers so I is not a good example. I think that problem of importing GeoPDF is rather a problem for GDAL/OGR dev team.
> And AFAIK they do not work on it due to it is porperatly format. Maybe ask GDAL devs about details.
GeoPDF recently became an open standard. The spec has been published.
Best,
Jeshua Lacock, Owner
<http://OpenOSX.com>
phone: 208.462.4171
