[GRASS-dev] WinGrass65 + import gui_modules.nviz_tools as nviz_tools: ImportError
Martin Landa landa.martin at gmail.com
Sun Jun 13 09:13:12 EDT 2010
2010/6/6 Glynn Clements <glynn at gclements.plus.com>:
>> I will revert r42490, because WinGrass7 (from the WinGrass-installer)
>> seems to need versioned libgrass_*.7.0.svn.dll in C:\Program
>> Files\GRASS-70-SVN\extralib for starting and unversioned
>> libgrass_*.dll C:\Program Files\GRASS-70-SVN\lib for wxnviz. with
>> r42490 WinGrass7 isn't starting, with reverted r42490 WinGrass7 is
>> starting but wxnviz (3D view mode) isn't working.
well, there is no reason why GRASS libs should be located in extralib
directory (speaking about native installer). Changed in r42547, GRASS
libs are moved to `lib` directory.
> Should the ctypes wrappers be changed to use the versioned library
> name?
Probably yes, just to avoid having copy of unversioned library names.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
