[GRASS-dev] Re: [GRASS GIS] #1032: ErrorCommandExecution g.proj
GRASS GIS trac at osgeo.org
Sun Jun 13 17:00:20 EDT 2010
 Reporter:  sallar   |       Owner:  grass-dev@…
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  6.4.0
Component:  default  |     Version:  6.4.0 RCs
 Keywords:  g.proj   |    Platform:  Linux
      Cpu:  x86-32   |
Comment(by martinl):
 Replying to [comment:15 martinl]:
 > Replying to [comment:14 glynn]:
 > > I'm not sure why the backtrace stopped (maybe the caller was built
 with -fomit-frame-pointer?), but it looks like heap corruption. In which
 case, the stack trace doesn't really help, as the error is in whatever
 caused the heap corruption, not whatever happens to get bitten by it.
 > > valgrind might be able to help here.
 > Can you post here valgrind output ?
 > http://grass.osgeo.org/wiki/GRASS_Debugging#Using_Valgrind
 The ticket is marked as "blocker", valgrind output could help to solved
 this issue.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1032#comment:16>
