[GRASS-dev] Re: [GRASS GIS] #1089: GRASS 6.5 manual broken link
GRASS GIS trac at osgeo.org
Tue Jun 15 19:15:03 EDT 2010
 Reporter:  timothymorrissey  |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  normal            |   Milestone:  Website
Component:  default           |     Version:  svn-develbranch6
 Keywords:                    |    Platform:  Unspecified
      Cpu:  Unspecified       |
Comment(by hamish):
 nope, failed with same
 Errors in:
 [...]/grass65/gui/wxpython
 6.5 breaks there for me too,
 make 2>&1 | tee build_log.txt
 make[3]: Entering directory
 `/usr/local/src/grass/svn/grass65/gui/wxpython'
 GISBASE="/usr/local/src/grass/svn/grass65/dist.i686-pc-linux-gnu" \
         python gui_modules/menudata.py > menustrings.py
   File "gui_modules/menudata.py", line 39, in ?
     import globalvar
   File
 "/usr/local/src/grass/svn/grass65/gui/wxpython/gui_modules/globalvar.py",
 line 33, in ?
     import grass.script as grass
   File "/usr/local/src/grass/svn/grass65/dist.i686-pc-linux-
 gnu/etc/python/grass/script/__init__.py", line 1, in ?
     from core   import *
 gnu/etc/python/grass/script/core.py", line 508, in ?
     debug_level = int(gisenv().get('DEBUG', 0))
 gnu/etc/python/grass/script/core.py", line 505, in gisenv
     s = read_command("g.gisenv", flags='n')
 gnu/etc/python/grass/script/core.py", line 216, in read_command
     ps = pipe_command(*args, **kwargs)
 gnu/etc/python/grass/script/core.py", line 193, in pipe_command
     return start_command(*args, **kwargs)
 gnu/etc/python/grass/script/core.py", line 155, in start_command
     return Popen(args, **popts)
 gnu/etc/python/grass/script/core.py", line 53, in __init__
     startupinfo, creationflags)
   File "/usr/lib/python2.4/subprocess.py", line 543, in __init__
     errread, errwrite)
   File "/usr/lib/python2.4/subprocess.py", line 975, in _execute_child
     raise child_exception
 OSError: [Errno 2] No such file or directory
 make[3]: *** [menustrings.py] Error 1
 make[3]: Leaving directory `/usr/local/src/grass/svn/grass65/gui/wxpython'
 make[2]: *** [install_scripts] Error 2
 make[2]: Leaving directory `/usr/local/src/grass/svn/grass65/gui/wxpython'
 make[1]: Leaving directory `/usr/local/src/grass/svn/grass65/gui'
 If I cd into the gui/wxpython dir and re-run make, then it builds ok.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1089#comment:3>
