[GRASS-dev] (no subject)
Maris Nartiss maris.gis at gmail.com
Wed Jun 16 04:21:46 EDT 2010
Hello Ken,
--enable-64bit doesn't deal with GRASS 64bitness in direct way. What
You should had looking for was compiling 32bit apps on 64bit OS.
Regarding float overflow - it makes sense. Can You attach a patch to
trac ticket? I (or somebody else) will take a look at it and commit to
SVN.
Thanks for spotting this. Moving conversation to -dev.
Maris.
2010/6/16 Ken Kwasnicki <ken.kwasnicki at gmail.com>:
> Yes, I my slackware can run 32bit apps. I tried recompiling grass without
> the --enable-64bit option but still had the same nviz problem , although i
> expect i'm still compiling to 64bit.
> However, I've looked at the togl_flythrough.c code and found the problem.
> Or at least found a change the fixes this on my system.
> I had added some debug output to mouse_valuator just to show the thisTime
> value, initially I just wanted to see if I would even see the output from a
> printf statement when running nviz.  What I noticed was that the "seconds"
> value for thisTime was not incrementing, only the decimal part was changing,
> which I guess is why the view would return to its original position after a
> 1 second lapse.
> in the function "this_time" the time values are being cast to float which is
> maxing out so i changed them to double which is the return value anyway.
> so, i changed this line [320]:
>     return ((float)tv.tv_sec + ((float)tv.tv_usec / 1000000.0));
> to:
>     return ((double)tv.tv_sec + ((double)tv.tv_usec / 1000000.0));
> and that appears to have fixed the problem.  the same change may need to be
> made for the MINGW32 version of the code, but I left that alone.
> i've made this change in my download of the 6.4.0RC6 version of the code but
> for now I'll leave it up to you, or others to make this change as I'm
> currently not set up to submit code.
> thanks!
> ken
> On 06/15/2010 12:53 PM, Maris Nartiss wrote:
> Hello,
> at first - You can compile 32bit version on 64bit machine (if it's
> possible on Slackware).
> Second - once I took a look at code. It was not good, still I didn't
> managed to find the root cause.
> Fly mode is TCL/C hybrid.
> TCL part is here:
> http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/visualization/nviz/scripts
> (flythrough.tcl)
> Some support is located in nviz/src/ (togl_flythrough.c)
> Main rendering is done by OGSF lib/ogsf
> OGSF should be fine, problem is somewhere in nviz part. Probably in
> C/TCL interaction.
> Good luck.
> If You need some help with coding, feel free to as at grass-dev ML. We
> are short on resources and thys any help is wecomed.
> Maris.
> 2010/6/15, Ken Kwasnicki <ken.kwasnicki at gmail.com>:
> Hi Maris,
> Thanks for the reply!  Too bad. I guess I'll have to install on a 32bit
> system.  For what it's worth my system is Slackware 13.0 64bit and also
> Nvidia driver, so nothing really new to add to the bug report other than the
> variance in linux distribution.
> Any speculation where this bug might occur in the nviz code?  Just in case
> I'm feeling ambitious enough to take a crack at debugging it.
> Thanks,
> Ken
> On 06/15/2010 12:14 AM, Maris Nartiss wrote:
> Known issue, currently no fix.
> http://trac.osgeo.org/grass/ticket/46
> Maris.
> 2010/6/14, Kwas <ken.kwasnicki at gmail.com>:
> Helo,
> I've used NVIZ in the past and not had this problem but after rebuilding
> Grass/Nviz for a new system (Slackware 13 64bit)  I now find when I try
> to
> "fly" to move the landscape it keeps resetting back to its originall
> position after a few frames.    ie: it will start to move in the
> direction
> of my mouse motion but then keeps jumping back so that I am unable to
> zoom
> in or position the view where I want.
> Has anybody seen this problem before or know what I should do to fix it?
> Appreciate any assistance.
> Thanks,
> Ken
> http://osgeo-org.1803224.n2.nabble.com/NVIZ-help-fly-keeps-resetting-jumping-back-to-center-tp5178852p5178852.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
