[GRASS-dev] Re: GRASS startup behaviour on Win differs from Unix
    Benjamin Ducke
    benjamin.ducke at oxfordarch.co.uk
    Wed Jun 16 04:48:57 EDT 2010
In answer to myself:
Init.sh has this:
  # User selects LOCATION and MAPSET if not set
  if [ ! "$LOCATION" ] ; then
  	# Check for text interface
  	text)
	    "$ETC/set_data"
Whereas Init.bat just does:
  :text
  "%WINGISBASE%\etc\set_data"
So it will always go to the interactive login,
no matter if $LOCATION is already set or not.
Wouldn't it be a good idea to have both scripts
behave identically?
Ben
----- Original Message -----
> Hi all,
> when I start GRASS from a Linux shell, going through Init.sh,
> I can supply the name of a mapset and GRASS will automatically
> log into that.
> When I do the same in Windows, from cmd.exe and going through
> Init.bat, I always get the interactive login screen. Is that
> intented behaviour? Or is there something I am doing wrong with
> the mapset path specification?
> Linux:
> grass64 $HOME/grassdb/test/usr
> -> logs straight into mapset
> Win:
> grass64.bat c:\grassdb\test\user
> -> goes to interactive login
> Cheers,
> Ben
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
