[GRASS-dev] Re: [GRASS GIS] #1090: Access is denied - r.statistics
GRASS GIS trac at osgeo.org
Wed Jun 16 09:45:37 EDT 2010
 Reporter:  nkale                                 |       Owner:  grass-dev@…
     Type:  defect                                |      Status:  new
 Priority:  normal                                |   Milestone:  6.4.0
Component:  Raster                                |     Version:  6.4.0 RCs
 Keywords:  r.statistics access denied, wingrass  |    Platform:  MSWindows 7
      Cpu:  x86-32                                |
Comment(by nkale):
 Didn't really follow anything below "note 0_sum.c in gr65...", but as for
 the commands you suggested:
 r.stats ag at PERMANENT - runs fine, no errors, meaningful output
 r.stats HUC at PERMANENT - runs fine, no errors, meaningful output
 g.tempfile pid=1234 - no errors, output is:
 C:/Users/Nat Kale/Documents/Grass_GIS
 DataBase/Alberts_Landcover/PERMANENT/.tmp/1234.1
 That is the correct location & mapset.  Can't think of anything else to
 try.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1090#comment:2>
